Hi, I have a hap ax3 as my main router, I configured the hotspot VLAN on its ether2 (
ax3_conf_mod.rsc (7.43 KB)
Then I configured the mantbox as AP (VLAN) and connected it to ether2 of hap ax3 (
mantbox_conf_mod.rsc (1.3 KB)
The configuration works (hotspot), but the problem is that the mantbox doesn’t appear on the winbox, so I can’t access it. However, when I disable VLANFILTERING on ax3, the mantbox appears on winbox. So it’s probably a VLAN configuration problem.
Can someone correct my configuration, I’m a novice. Thanks for your help.
