need help with vlan
I am trying the wiki instructions right now, not having any luck.
433 plugged into port 4 on a 750. Just in case I was doing it wrong, I copied it straight from the wiki, test vlan id 32, 10.10.10.1/24 and 10.10.10.2/24, vlan test attached to port 4 on the 750 and ether1 on the 433 and can’t ping across.
ROS v4.9.
I’ve used vlans on HP Procurve switches. I’ll admit I don’t use vlans that often, however, I don’t see where it is that difficult.
I’ve got an AP (AP 10.0.22.0/24, ptp 10.1.22.0/24, office 192.168.0.0/24) that I am adding more ptp shots from. I have one ethernet cable run down the tower that feeds my office. I need to keep the office separate from the ptp and ap subnet. I was going to set vlan1 to ether1 on the rb600 and through a rb750 to a rb433.
I have configured vlan on ether1 interface of the 433 and port 4 on the 750, ip addresses of 10.10.10.1/24 and 10.10.10.2/24 (just for testing, will use 10.1.22.x/24). Vlan shows Running, however I can’t ping across it. Am I missing something?
By default RB750 has ether2 to ether5 switched. Do you have default configuration on RB750? If yes then remove switch configuration and then try vlan setup again.
thanks, will do.
That worked!
Thanks!
