Need help with VLANS and routing their traffic over L2TP
I’m somewhat new to Mikrotiks but have created the site-site L2TP connections from customer router to our phone server’s router (all mikrotik).
I’m in the process of updating customers to use the newly created L2TP connection for phone traffic to the main phone server’s mikrotik.
I’ve created a template on my test network and have implemented it in the field a handful of times without issue. The phone traffic goes through the L2TP connection to the private IP of the phone server.
On some customer sites, when I try to route over the newly created L2TP connection, it just won’t route.
I can register the phones using the public IP of our phone server, the L2TP connection says connected, but when I change the phones to use the private IP of the phone server they won’t work.
For example: Phones on vlan100 will register to a public IP but won’t route over the L2TP connection.
How can I get help with this problem?
I don’t know the logistics of posting here and how to exclude real IP addresses (so we don’t get hacked more than normal).
Any/all help is greatly appreciated.
Thanks!
post /export hide-sensitive of both routers.
Also easy way to test connectivity, put a computer on a phone IP on that VLAN and make sure it can PING the VoIP server, also maybe check traceroute see where its stopping if there are multiple hops in the path.
Ok, here's 1st try at posting output:
[admin@Customer_Mikrotik] > /export hide-sensitive
oct/29/2018 15:59:18 by RouterOS 6.43.2
software id = 7VXJ-4R8J
model = RouterBOARD 750G r3
serial number = 6F390629E5AD
add admin-mac=6C:3B:6B:C0:6F:35 auto-mac=no comment="created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] comment=WAN mac-address=6C:3B:6B:C0:6F:34 speed=100Mbps
set [ find default-name=ether2 ] comment="Main Switch" mac-address=6C:3B:6B:C0:6F:35 name=ether2-master speed=100Mbps
set [ find default-name=ether3 ] comment="to the switch" mac-address=6C:3B:6B:C0:6F:36 speed=100Mbps
set [ find default-name=ether4 ] mac-address=6C:3B:6B:C0:6F:37 speed=100Mbps
set [ find default-name=ether5 ] mac-address=6C:3B:6B:C0:6F:38 speed=100Mbps
/interface vlan
add interface=bridge1 name="Guest Vlan101" vlan-id=101
add interface=bridge1 name="VOIP Vlan 100" vlan-id=100
add comment="VPN VLan" interface=bridge1 name=vlanVPN vlan-id=102
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
/ip ipsec peer profile
add dh-group=modp1024 dpd-maximum-failures=2 enc-algorithm=aes-256,aes-128,3des name=profile_1
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des pfs-group=none
add name="VOIP Pool" ranges=192.168.50.10-192.168.50.50
add name=vpn-pool ranges=192.168.89.2-192.168.89.250
add name="Guest Pool" ranges=192.168.100.10-192.168.100.250
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add address-pool="VOIP Pool" authoritative=after-2sec-delay disabled=no interface="VOIP Vlan 100" lease-time=1d name="VOIP DHCP"
add address-pool="Guest Pool" authoritative=after-2sec-delay disabled=no interface="Guest Vlan101" lease-time=1h30m name="Guest Pool"
add address-pool=vpn-pool authoritative=after-2sec-delay disabled=no interface=vlanVPN lease-time=1d name=VPN-DHCP
/ppp profile
add dns-server=8.8.8.8 local-address=192.168.89.1 name=VPN-profile remote-address=vpn-pool use-encryption=yes wins-server=8.8.4.4
add local-address=172.16.203.2 name=L2TP-Out remote-address=172.16.203.1
set FFFFFFFE dns-server=8.8.8.8 local-address=192.168.89.1 remote-address=vpn-pool wins-server=8.8.4.4
/interface l2tp-client
add allow=mschap1,mschap2 allow-fast-path=yes connect-to=
...* disabled=no mrru=1600 name=Site2Site_Customer profile=L2TP-Out
use-ipsec=yes user=Site2Site_Customer_User
/queue simple
add name=Total target="VOIP Vlan 100"
add max-limit=4M/4M name=VOIP packet-marks=VOIP_PKT parent=Total priority=1/1 target="VOIP Vlan 100"
add max-limit=3M/15M name=Guest target="Guest Vlan101"
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=VPN-profile enabled=yes use-ipsec=yes
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface="VOIP Vlan 100" list=discover
add interface="Guest Vlan101" list=discover
add interface=vlanVPN list=discover
add interface=Site2Site_Customer list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.1.1/24 comment=defconf interface=bridge1 network=192.168.1.0
add address=192.168.50.1/24 interface="VOIP Vlan 100" network=192.168.50.0
add address=174.77.226.178/27 interface=ether1 network=174.77.226.160
add address=192.168.100.1/24 interface="Guest Vlan101" network=192.168.100.0
add address=192.168.89.1/24 interface=vlanVPN network=192.168.89.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge1 lease-time=1h name=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
add address=192.168.50.0/24 gateway=192.168.50.1
add address=192.168.89.0/28 gateway=192.168.89.1
add address=192.168.100.0/24 gateway=192.168.100.1
set allow-remote-requests=yes cache-max-ttl=1d servers=68.105.28.16,68.105.29.16
/ip dns static
add address=192.168.1.1 name=router
add action=drop chain=input comment="Block Port 53" dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input comment="Block Port 53" dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=forward comment="Block Port 53" dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=forward comment="Block Port 53" dst-port=53 in-interface=ether1 protocol=tcp
add action=accept chain=forward comment="Guest to LAN DROP" dst-address=192.168.50.0/24 src-address=192.168.1.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.1.0/24 src-address=192.168.50.0/24
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=accept chain=input comment="allow l2tp" dst-port=1701 in-interface=ether1 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 in-interface=ether1 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new
disabled=yes in-interface=ether1
/ip firewall mangle
add action=mark-connection chain=prerouting dst-port=5060 new-connection-mark=VOIP-Conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting connection-mark=VOIP-Conn new-packet-mark=VOIP_PKT passthrough=yes
add action=change-dscp chain=postrouting dst-port=5060 new-dscp=7 passthrough=yes protocol=tcp
add action=change-dscp chain=postrouting dst-port=5060 new-dscp=7 passthrough=yes protocol=udp
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="masq. vpn traffic" dst-address=192.168.1.0/24 src-address=192.168.89.0/24
add action=dst-nat chain=dstnat in-interface=ether1 protocol=tcp to-addresses=192.168.1.150 to-ports=8000
add action=dst-nat chain=dstnat in-interface=ether1 protocol=tcp to-addresses=192.168.1.150 to-ports=2000
add action=masquerade chain=srcnat comment="masq. vpn traffic" disabled=yes src-address=192.168.89.2-192.168.89.254
/ip ipsec peer
add address=0.0.0.0/0 exchange-mode=main-l2tp generate-policy=port-override local-address=192.168.89.1 passive=yes profile=profile_1
add name=dhcp next-pool=dhcp ranges=192.168.1.10-192.168.1.150
add distance=1 gateway=174.77.226.161
add disabled=yes distance=1 dst-address=8.38../32 gateway=Site2Site_Customer pref-src=172.16.203.2
add distance=1 dst-address=10.201.21.0/24 gateway=Site2Site_Customer pref-src=172.16.203.2
add distance=1 dst-address=10.201.21.10/32 gateway=Site2Site_Customer pref-src=172.16.203.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp secret
add name=dsr profile=VPN-profile service=l2tp
add name=vpn profile=VPN-profile service=l2tp
add name=Customer profile=VPN-profile service=l2tp
/system clock
set time-zone-name=America/New_York
/system identity
set name=Customer_Mikrotik
/system resource irq rps
set ether1 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Is anything wrong with the routing of my VOIP VLAN in this config?
I’m trying to route the VOIP over the L2TP connection.
Add a routing mark and default routing entry:
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=VOIP-Conn \
    in-interface="VOIP Vlan 100" new-routing-mark=Via-Site2Site passthrough=yes
add gateway=Site2Site_Customer routing-mark=Via-Site2Site
https://wiki.mikrotik.com/wiki/Policy_Base_Routing
