Need help with WISP
hello guys ! i know im asking alot but i need some help.
im starting up a wisp, and im about to have the fiber optical. i had a partner .. but things changed anyway.
i reseted the RB and got 1 setup online in 2 days of work without knowning much …
here is my setup
( Main ) tower 1: RB433
  • 1 minipci 2.4mhz radius on a ovni
  • 1 minipci 900mhz beam 15 dbi horizontal NLOS to Tower 2
    ( i should maybe buy a 5 ghz setup ) as im living in a small town country side.
Tower 2: RB433
  • 1 minipci 900mhz beam 15 dbi horizontal NLOS to Tower 1
  • 1 minipci 900mhz radius on a ovni
I need help to set this setup ,users and bandwidth management and a hotspot
do i need anything else ?
Also Bad blocks went 2.3% to 2.9% in the 2 days of work
is that normal ? can i do anything to help on that ?
Thanks alot for for helping me out guys !!
support ?
With something like this you should probably hire a consultant.
http://www.mikrotik.com/consultants.html
Thanks alot for your helpfull info !! few hints would have work perfectly also
These are some of the basic things you might want to have correct to have a successful WISP. There are just so many variables that it is hard to tell you exactly what you would need. But this is a good start for your reading.
http://wiki.mikrotik.com/wiki/How_to_setup_up_RADIUS_for_use_with_MikroTik_-_By_Ramona
http://wiki.mikrotik.com/wiki/Manual:Interface/PPPoE
http://wiki.mikrotik.com/wiki/Manual:HTB
http://wiki.mikrotik.com/wiki/Manual:Queue
http://wiki.mikrotik.com/wiki/Manual:Routing/OSPF and maybe with http://wiki.mikrotik.com/wiki/Manual:MPLS
We are seeing same type of NAND corruption leading to system failure. We are looking for more data to help determine root cause.
Any additional info, please add to http://forum.mikrotik.com/t/hardware-issues-with-rb4xx/56059/1 thread.
