I accidentally disabled the Ethernet interface and lost communication with the device. I tried to reset it, but still doesn’t work. can someone please help me!!!
The Quick Guide contains the steps to follow to reset the device. If this is not working, please describe what model and what steps you are executing.
If you have disabled a single ethernet interface on a multiple interface device, you may connect your computer to another ethernet port and discover the device using Winbox to regain access.
