The RB4011 is booting on loop no matter what I do, after firmware update " right one, no energy cut in process " .
What can I do, I tried reset button, 4 sec / 20 sec / 3 min…nothing… all ports are dead except wan, when I try to connect wan with a pc to try Netinstall recover mikrotik os it keeps restarting on loop.
Tried connecting netinstall, winbox, direct cable pc>router / pc>switch>router.
Windows / Linux
Tried also the 30-30-30 reset mode, nothing worked…
Linux cooked capture
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
Bootstrap Protocol
Message type: Boot Request (1)
Hardware type: Ethernet (0x01)
Hardware address length: 6
Hops: 0
Transaction ID: **********
Seconds elapsed: 7
[Expert Info (Note/Protocol): Seconds elapsed appears to be encoded as little-endian]
[Seconds elapsed appears to be encoded as little-endian]
[Severity level: Note]
[Group: Protocol]
Bootp flags: 0x0000 (Unicast)
Client IP address: 0.0.0.0
Your (client) IP address: 0.0.0.0
Next server IP address: 0.0.0.0
Relay agent IP address: 0.0.0.0
Client MAC address: ::::: (:::::)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: DHCP
Option: (60) Vendor class identifier
Length: 9
Vendor class identifier: ARM__boot
Option: (255) End
Option End: 255
Padding: 000000000000000000000000000000000000000000000000…
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1591587211.355646180 seconds
[Time delta from previous captured frame: 0.200294473 seconds]
[Time delta from previous displayed frame: 0.200294473 seconds]
[Time since reference or first frame: 108.837547796 seconds]
Frame Number: 15
Frame Length: 344 bytes (2752 bits)
Capture Length: 344 bytes (2752 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: sll:ethertype:ip:udp:bootp]
Any idea?
