need help
Hi..
In my netwok i m using mikrotik as a webproxy server and as firewall. All systems including a server having same pool of IPs i.e 192.168.3.0/24.all system are able to access internet.Now i want only two system to deny access to my server i.e 192.168.3.2 but should access internet .How can i do it.plz help me…
thanx
I’m not with you. Do you want all users except two to access the internet or what?
I’m not sure why you reference the server?
You can use filter rule…
if your users connect to server not via ROS, you cannot block their communications on ROS
ya..u r right…its not going thru ROS.1st all connected to switch then firewall so i can not block…any way thanx u all for answering …
thanx
