need help
How can i remove simple queue from the router???
i am currently using the PHP API provided at http://wiki.mikrotik.com/wiki/API_PHP_class
by Denis Basta…
i need to run “/queue simple remove <queue_name>”
using PHP API
Using the PHP client from my signature, you can do pretty much exactly that:
<?php
using PEAR2\Net\RouterOS;
require 'PEAR2_Net_RouterOS-1.0.0b3.phar';
$client = new RouterOS\Client('192.168.0.1', 'admin', 'password');
$client(new RouterOS\Request('/queue simple remove numbers=<queueName>'));
But if you insist on using Denis’ client, then it would be more like
<?php
require 'routeros_api.class.php';
$API = new routeros_api();
$API->connect('192.168.0.1', 'admin', 'password');
$API->comm('/queue/simple/remove', array('numbers' => '<queueName>'));
thank u so much , it worked… thankx
