Hi guys ..
i have a problem …
i have a 3 ADSL internet lines and combining it together using tplink tl r480t and i have a mikrotik router board for my costumers my problem is after small amount of time i loss the internet connection behind my mikrotik until i restart it i get the connection again and loss it again after seconds i don’t know what is the problem ?
when i connect the modem directelly to the mikrotik router board no any problems…
this is my configuration in mikrotik
add name=dhcp_pool1 ranges=10.10.0.2-10.10.255.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=\
static disabled=no interface=ether1 lease-time=10h name=dhcp1
add address=10.10.0.1/16 comment="hotspot network" disabled=no interface=\
ether1 network=10.10.0.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no interface=\
ether2 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=10.10.0.0/16 dhcp-option="" dns-server="" gateway=10.10.0.1 \
ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=8.8.8.8
add disabled=no distance=1 dst-address=0.0.0.0/32 gateway=192.168.1.1 scope=\
30 target-scope=10
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=Server
/system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
