need help
hello i need help on my login in page
when i change the login.html and put some pic and text on it
when the user come and wanna login in they put there user and password
nothing happend
can any one help me in that or give me script for user and password and told me how to use it plz
thx
You should only modify those HTML carefully and when you know what you do. There is javascript in there, which is essential for a working login page.
I suggest starting over again (by resetting the HTML hotspot pages to the default) and carefully modify/add things again.
Best regards,
Christian Meis
Hi
If you want to change your hotspot Login page read this
1- design you home page with any program (( Front page , MMFlash …etc ))
2-after complete your design edit it with notepad or WordPad
3- search on this Tage
4- put this code after the above tage
<body>
$(if chap-id)
	<form name="sendin" action="$(link-login-only)" method="post">
		<input type="hidden" name="username">
		<input type="hidden" name="password">
		<input type="hidden" name="dst" value="$(link-orig)">
		<input type="hidden" name="popup" value="true">
	</form>
	<script language="JavaScript" src="/md5.js">
	</script>
	<script language="JavaScript">
	    function doLogin() {
		document.sendin.username.value = document.login.username.value;
		document.sendin.password.value = hexMD5('$(chap-id)' + document.login.password.value + '$(chap-challenge)');
		document.sendin.submit();
		return false;
	</script>
$(endif)
5- Now put the below table in your home page in any location in the page you want
<table width="240" height="240" style="border: 1px solid #cccccc; padding: 0px;" cellpadding="0" cellspacing="0">
<tr>
<td align="center" valign="bottom" height="175" colspan="2">
	<form name="login" action="$(link-login-only)" method="post"
	    $(if chap-id) onSubmit="return doLogin()" $(endif)>
			<table width="100" style="background-color: #ffffff">
				<tr><td align="right">login</td>
						<td><input style="width: 80px" name="username" type="text" value="$(username)"/></td>
				</tr>
				<tr><td align="right">password</td>
						<td><input style="width: 80px" name="password" type="password"/></td>
				</tr>
				<tr><td>&nbsp;</td>
						<td><input type="submit" value="OK"></td>
				</tr>
			</table>
		</form>
</td>
</tr>
</table>
$(if error)
<br><div style="color: #FF8080; font-size: 9px">$(error)</div>
$(endif)
</td>
</tr>
</table>
7- now search on and put this code before it
  document.login.username.focus();
</script>
</body>
now the compelte HTML page
<html>
<body>
$(if chap-id)
	</form>
	</script>
		return false;
	</script>
$(endif)
<tr>
				</tr>
				</tr>
				<tr><td>&nbsp;</td>
				</tr>
			</table>
		</form>
</td>
</tr>
</table>
$(if error)
$(endif)
</td>
</tr>
</table>
</script>
</body>
</html>
Just if you want put your title to use IE Title
Any more quistion ??
I’m tryin to perform several actions before the user logs in the system and the problem is that my login.php page to which I redirect the user does not work. I know that I have to pass the parameters from the user to it, but I have no clue how. Can someone hlep me?
thanks
Regards
This wiki explains the basic setup you need to make it work
