i need to setup 60 km p2p , please send some best technical board and antenna details…
what’s your budget, what are the requirements, what is the line of sight and interference there?
hi normis ,
There is no Interference,Range is Nearly 50 Km , Clear Line of Sight, Budget is 500$.. already i have RB 411 + R52 with 24 db Parabolic Grid Antenna..is it enough.. or any special configuration..please tell the best solution
Regards
Rajesh.R
I didnt set such a link but in my opinion
Get your self a high powered radio card like XR5 or XR2
Find a dish more than 30db
use RB600 since it is fully PoE compliant to power feed the cards better.
Get a better antenna, but you will run out of budget. I think you should take a look to >30dB antennas (32dB, or higher). Consider at least to use XR5 or better accordingly to local regulation.
Good luck.
