Need hotspot device information
Which MikroTic product is better in handling the hotspot (captive portal) users. It should be able to handle at least 200 (500 max) concurrent users. Would it be possible?
For demo purposes, I received this device:
RB951Ui-2nd (hAP serries)
Dear,
You should better go for RB3011RM.
Your talking about this device?
routerboard.com/RB3011UiAS-RM
Thank you so much dear.
Hello
RB1100AHx2 or CCR1009
Then CCR1009 cause it’s a newer device.
RB1100AHx2 is also good but production may be stopped.
I advice you use RB1100AHx2 or CCR1009. They perform well.
just remember user manager cannot be installed in rb3011.
“there is currently no User Manager for ARM systems (RB3011). Maybe in RouterOS v7 it will exist for ARM too.”
