Need Mikrotik L2TP No other way. Please help..!
Dear,
Mikrotik Behind the ISP router.ISP router has static public IP. I want to set up L2TP VPN Server in Mikroitk.
Is it possible with port forwarding in the ISP router?
WIreguard is possible, dont use L2TP…
thanks for reply Sir,
can you please tell me what is the way?
Actually, I want to access my local network remotely. Is it the best option for remote access?
wire guard is possible with port forwarding or without port forwarding?
It is not possible if you are missing a public IP address at the MT Device AND you cannot forward a port.
In this case you can forward the port and very much possible and is an excellent way to
a. access your router for config purposes
b. access your LAN devices.
Example additions to config.
MT ROUTER (server)
/interface wireguard
add listen-port=15831 mtu=1420 name=WG
/interface list members
add interface=WG list=LAN
/interface wireguard peers
add allowed-address=10.20.30.2/32 public-key=“+…”
add allowed-address=10.20.30**.3**/32 public-key=“+…”
add address=10.20.30.1/24 interface=WG network=10.20.30.0
add action=accept chain=input comment=“Wireguard handshake” dst-port=15831 protocol=udp
add action=accept chain=input comment=“Admin router access” in-interface=WG
add action=accept chain=forward comment=“Admin lan access” in-interface=WG out-interface-list=LAN
MOBILE WIREGUARD CLIENT SETTINGS… ( if windows, ensure you get from wireguard website not microsoft )
Will assume you have TWO CLIENT DEVICES
LAPTOP
Settings → interface name=WireguardL / ip-address=10.20.30**.2**/32
add allowed-address=0.0.0.0/0 endpoint-address=ISPpublicIP endpoint-port=158311
interface=WireguardL persistent-keepalive=25s public-key=“…”
SMARTPHONE
Settings → interface name=WireguardS / ip-address=10.20.30.3/32
interface=WireguardS persistent-keepalive=35s public-key=“-------”
Normally, the allowed IPs at the client device includes the wireguard subnet, and any subnets on the server router you are visiting.
0.0.0.0/0 covers both of those and also allows the mobile remote user to access the internet of the server router.
Tons of reading here → https://forum.mikrotik.com/viewtopic.php?t=182340
Sir EOIP tunnel can be established on wireguard VPN?
Example here… The first half is EOIP over wireguard…
https://forum.mikrotik.com/viewtopic.php?p=990837#p990836
