Need OID For Temperature To Monitor Via SNMP
In Winbox, going to system, health, gives a readout of the “CPU Temperature.” Are there any other temperature readings available for monitoring and if so where do you find them and Winbox and what are the OID’s for all the temperature readings available for monitor via MRTG SNMP data graphing?
This is how you can find the OIDs:
[admin@normis] /system health> print oid
             active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
                voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
            temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
  processor-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
ah. that is totally freakin’ sweet, Normis. super helpful. thanks, man. kudos to the firmware engineers for including that little tid bit of usefulness.
Dear Members,
please can anyone tell me how to use this function on dude ?
Topic seems pretty old, still question is unanswered so here it comes.
In device appearance add something like:
[Device.Name]
IP: [Device.FirstAddress]
[device_performance()][Device.ServicesDown]Uptime: [oid(“1.3.6.1.2.1.1.3.0”)]
Temperature: [oid(“1.3.6.1.4.1.14988.1.1.3.10.0”)/10] °C
There are 2 oids- first one is uptime and the second one is temperature divided by 10.
This is because output of oid is an integer and it cannot handle floating point number and it’s for example 340 instead of 34.0.
Thank You for your reply
For RB750Gr3 (6.41.3)
Temperature: [oid(“1.3.6.1.4.1.14988.1.1.3.10.0”)] °C
shows real temperature (32°C)
But for RB750G (6.41.3)
shows nothing (empty value)
Why?
If I remember correctly RB750G doesn’t have temperature/voltage sensor.
Check with /system health print
You are right.
Hi everybody, I have a problem when I try to get the voltage value from 750GL router using the snmp protocol.
The terminal of 750GL show the OIDs of system health:
[admin@MikroTik] > system health print oid
current: .1.3.6.1.4.1.14988.1.1.3.13.0
fan-speed: .1.3.6.1.4.1.14988.1.1.3.17.0
fan-speed2: .1.3.6.1.4.1.14988.1.1.3.18.0
power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
When I use the command snmpGet I get the following:
D:\SNMP>snmpGet -v:1 -c:public -r:192.168.3.1 -o:.1.3.6.1.4.1.14988.1.1.3.8.0
SnmpGet v1.01 - Copyright (C) 2009 SnmpSoft Company
[ More useful network tools on http://www.snmpsoft.com ]
%Failed to get value of SNMP variable. Variable does not exist (noSuchName(2))
However when I use other OID the request is succesful:
D:\SNMP>snmpGet -v:1 -c:public -r:192.168.3.1 -o:.1.3.6.1.2.1.2.2.1.2.1
Is it possible to get the voltage value from 750GL and how?.
Thanks in advance.
Normis whre is the board temperature OID in CCR1016-12G ?. Not show in system/health> print oid
