Need old image
want to upgrade an old remote RB500 which has 2.9.48 and wireless-crd
installed.
I want to test the upgrade on another RB500 to make sure I dont need
to travel.
So can someone provide me a 2.9.48 Image and a 2.9.48 wireless-crd
Package.
Thanks,
Stefan
how would the same version packages help you in this case ?
I downgrade a RB500 on my desk to the same version the remote system has and
then do the upgrade on my desk. So If upgrade kills my wireless-connection I have
to travel for the upgrade. If upgrade goes ok I can dare to do the remote upgrade.
http://mt.lv/download/temp/wireless-crd-2.9.48-ns.npk
http://mt.lv/download/temp/routeros-rb500-2.9.48.npk
but remember, there are other failure factors that you can’t predict.
Thanks. Got them.
Updating is hot stuff !!
Downgraded to 2.9.48 / wireless-crd
Uploaded 2.9.51 complete package + wireless-crd package
Reboot
Update to 2.9.51 is ok. But: Active package is normal wireless package. wireless-crd is installed
but disabled.
wireless-crd doesn’t do anything for your router, it just changes some compliance mode. in later versions this package is not needed anymore. most important thing is - did your wireless connection stay active after the upgrade?
Yes. My Testsystem stayed online. So I will do an upgrade of the live system.
Nevertheless I wait for better weather in case of …
