What is the proper configuration to bridge a ethernet port on a pc to a wireless network using a RB532. I tried a simple wlan1 to ether1 bridge to no avail. the pc pulled an ip from the wireless but will not ping.
Thank you
Thank you
about wireless access point configuration pleace read this
you should be able to configure everyting you need
good luck ![]()
I dont think the instructions talk about using mikrotik as a an ethernet to wireless bridge.
Read my last post on this thread for details on how to do this.
(joke) “Use the search button, Luke…that’s what it’s there for!” (/joke) ![]()
– Nathan
(edit) …or, as others will (wisely) tell you, if it is an option for you, just use WDS.
Thank you Nathan, IT shouldnt have to be that difficult. It amazes me i can get a $70.00 linksys and flash it with some DDWRT and i have a working bridge in minutes.
Just my 2cents
in4ni, yes you cannot brigde ‘mode=station’ (explanation)
However, it’s possible to bridge using WDS or EoIP features.
