Need proper default config for hAP lite
I recently bought a hAP lite wireless router from Amazon. I was working on configuring it, and I made a mistake so I needed to use the reset button. I held it for 5 seconds after power on as the instructions said, and it came back up.
But it didn’t come up with the same config as it shipped with. For example, the wireless is not enabled. And it appears to be in bridge mode, not router mode. This happens if I use the “Reset Configuration” button in the GUI or by using the reset button. I can’t get it back to the configuration it shipped with. This seems like a bug.
I’m trying to configure it as a wireless router, but every time I try to make a change to it I seem to break it and I lose access.
Can someone send the proper default configuration for this device with basic instructions on how to load it?
Otherwise I have to return it.
Thanks.
Please wait for v6.30 release where default configuration is fixed.
When is v6.30 expected to drop?
Usually still the same answer: when developers think it is ready.
Already out, came literally 24 hours after posting that.
Yes thanks. My problem was only that I needed to set the dropdown on the “quick set” page correctly. But it’s fixed now in the new code level.
Really enjoying the hAP. What a deal. Just need to learn RouterOS better now.
