Need to disable and re-enable wireless interface named NORTH every 30 minutes because of a problem we are having.
Would be good if the interface was disable for maybe 10 seconds before re-enabling.
Thanks for your help!
Nevermind, I found the solution by modifying this script posted a while ago:
