Need remote access without port forward
Hi Community ! This is my first post and i think it the begin of a new story, i have buy some mikrotik in the past and i have love it and now i want to play more deep with the configuration.
I will need the help of all GURU :slight_smile:
My first post will be about the Remote access and managing multiple router, my need its to put my hardware in an existing network without to make some port forward rules on the main router.
-One port of the remote LAN will be plug in the WAN port of the mikrotik, and i will have a internal ip. (Double NAT)
I have try to figure how to setup reverse SSH from the mikrotik, or maybe a VPN connected to my own server in my network.
who can tell me what is the best solution?
And sory for my english, i do my best…
Thank you
The MikroTik is behind another router?
You should start managing the network from the top. If you don’t have access to main router then it is not your network and you only can initiate a tunnel from inner device to outer world. So do it.
Yep the mikrotik, is behind another router i am double NATed, the WAN of the mikrotik have a private network IP.
Did you try to configure your Mikrotik as Vpn client?it must work.
