Need help with a script to run Btest that can be ran late at night for about 5 minutes.
u can use the scheduler.
and to see the graph, you have to enable the graphing under the tools.
Unfortunately I am not familiar with scripting. I wished there was some where to learn this here in my local.
Maybe the best thing is to hire some one to write the script that I need. It is a little more complicated than a simple btest. I will pay thru paypal $30usd for a working custom script that I require. PM me for the specific details of the script.
hi, are you able to make it with the scheduler?
What I would like to do is to run a test on two different freq (chan 1 and chan 11 in the 2.4 band) at around 2 in the morning when there is little traffic. There needs to be a delay between freq changes for the other radio to lock in on the ap freq change before the next test starts. Each test needs to run for about 2 min and record the results or email them to me so I can look at them in the morning
this can be done by the scheduler as well.
and you can record the bandwidth test result by the mrtg or the prtg or the equipment build in mrtg graph.
