Hi
I nead a script to change the current hotspot html directory automatically.
Is that possible?
Any help will be appreciated.
Hi
Is that possible?
It might be the following,
/ip hotspot profile> set 0 html-directory=
But keep in mind that 0 should be replaced with other option, as there is no print support in the scripts, you will need to use find to change specific server html-directory.
i set this: /ip hotspot profile set [find default=yes] html-directory= "
its work. tanks
