Need Script for dot.tk DynDNS
hi guys
i need script to update dynamic dns for dot.tk.
i searched in google and mikrotik wiki.
i used this script that wrote for DynDNS.org, i changed “user” “password” “hostname” and even “address”, but didn’t work.
here it is script that i used:
# Set needed variables
:local login "user"
:local password "password"
:local hostname "****.tk"
:global dyndnsForce
:global previousIP
# print some debug info
:log info ("UpdateDynDNS: login = $login")
:log info ("UpdateDynDNS: password = $password")
:log info ("UpdateDynDNS: hostname = $hostname")
:log info ("UpdateDynDNS: previousIP = $previousIP")
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:delay 1
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "UpdateDynDNS: currentIP = $currentIP"
# Remove the # on next line to force an update every single time - useful for debugging,
# but you could end up getting blacklisted by DynDNS!
#:set dyndnsForce true
# Determine if dyndns update is needed
# more dyndns updater request details http://www.dyndns.com/developers/specs/syntax.html
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
   :set dyndnsForce false
   :set previousIP $currentIP
   :log info "$currentIP or $previousIP"
   /tool fetch user=$login password=$password mode=http address="updatedns.tk" \
      src-path="nic/update?system=dyndns&hostname=$hostname&myip=$currentIP&wildcard=no" \
      dst-path="/dyndns.txt"
   :delay 1
   :local result [/file get dyndns.txt contents]
   :log info ("UpdateDynDNS: Dyndns update needed")
   :log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
   :put ("Dyndns Update Result: ".$result)
} else={
   :log info ("UpdateDynDNS: No dyndns update needed")
my router os version is 5.21.
please help me.
if you use changeip
try this
http://www.changeip.com/MikroTik/5.x.txt
works fine with me
thank you
but it’s not work on dot.tk.
