need script to remove queue ???
I am need a script , when i run it remove all queue which in /queue simple
my router v : 3.30
/queue simple disable [find]
use disable better than remove i think that
it back to you
/queue simple remove [find]
/queue simple {
   :foreach item in=[find] do={
      remove $item
u can test main
dssmiktik
What do you mean?
Wonderful :smiley: … Work very well
Thank you very much
disable does not work with dynamic queues
work with one
thank you
