Hello folks,
Don’t ask me why
, but I need a script that will act like watchdog.
So script should reboot Mikrotik each time the connection to certain IP address is lost.
Hello folks,
Don’t ask me why
But I have to ask why ![]()
Doesn’t the netwatch utility do what you want to do? It’s meant for just such purposes…
Cheers cmit ![]()
Well, I have installed mikrotik on mini-itx motherboard and Compact Flash drive and problem is when I do manual reboot it does reboot, but any other system reboot is hanging.
So, during installation, when it comes to reboot part, I was forced to unplug power cord to actually reboot.
When watchdog should reboot (but hangs the system), again power cord helped?!
Only winbox or terminal /system reboot is working without probs?!
I don’t know why?!
This is why I said not to ask me why ![]()
So, I think it is obvious why I need script, cause I guess it will actually call terminal command and reboot.
God help me with this ![]()
Hm, come on guys, I am sure you can do this…
Set watch-address in / system watchdog to the IP and it will reboot the IP is unreachable.
what if system is not responsive?
http://www.mikrotik.com/docs/ros/2.8/appex/scripting1
See about a quarter of the way down the page “A Ping based Netwatch”. Just change email code to /system reboot.
Hope that helps.
Then it wont work with a script or anything software, now will it?
If a system is not responding you need a hardware watchdog.
More precise link would be:
http://www.mikrotik.com/docs/ros/2.8/appex/scripting1||0.1859428017450315
Like one found on RouterBOARDs
sten, I told ya, it is hanging the system. I am using watchdog on other routers, but here it wont work…
Thx GJS and Eugene, this is exactly what I need ![]()
It’s working, if i shutdown link, system is finally rebooting ![]()
Cheers Folks…
