Need some cool, and true working script !
:slight_smile: Hello people…
I’m searching for a script that will every day at time 11:30 will disable ONE or more users from UserList and then at 8:00 am will enable it again !!!
:unamused:
PLZ - Write a full example of script, and how to run it, cose I’m noobie in scripting on MikroTik.
just make an ip address list of the users that you want to disable, and then a firewall rule that does action=drop on this list.
you will then have to make a very simple script - one that disables or enabled this firewall rule at a certain time.
Make address list:
/ip firewall address-list add list=drop_traffic address=192.0.34.166/32
Make drop rule:
/ip firewall filter add action=drop chain=forward src-address-list=drop_traffic comment=DROPME
Make script:
system script> add name=drop_users source=/ip firewall filter enable DROPME
Make scheduler rule:
system scheduler> add interval=24h name="drop_users" \
\... start-time=9:00:00 on-event=drop_users
not tested, just a loose example !
:slight_smile: Wow - thx IT REALY WORKS !!!
Here is another small question - is it possible to somehow control users conected to my server With MikroTik trough FTP?
I mean - can I create user that will only be able to connect to FTP and JUST read files from it, not delete or change them ?
you mean connect to mikrotik’s ftp? sure, make user with the group that has privileges of only ftp, read. i guess it should work
:cry: shuld work but - doesnt!
I got MikroTik 2.9.2 and many times tryed to do like you sayd but it really don’t work - I still can delete files from that FTP … Help…
And MOST IMPORTANT QUESTION - CAN I RUN PERL SCRIPTS ON MY MIKROTIK ??? if yes, then HOW and WHERE ? :unamused:
Mikrotik it is a router. You can not run perl script. Only built script language is support..
Update to the last version.
Maximiliano Dobladez
MCC
maxi como puedo contactar contigo, para hacerte alguna pregunta en especial del mkt?
my mail is: elmaxi [at] gmail.com
Maxi
