Hello guys,
i’m completely new at scripting, but i mannaged to created a scipt that does the folllowing and i’m actualy proud of it
1st: check if an interface (ether2 ->… depending on how many eth interfaces) is running
2nd: if yes look if the neighbor is a mt
3th if Yes, set bridge to “bridgeVLAN” if no, set bridge to “bridgePUBLIC”
This for automated security reasons inside our networks
Mt → 60 range IP’s
public Users (PC, PS4,…) → 20 range IP’s
script:
do {
:if ([/interface get ether2 running] = true) do={
:global CI2 0
:global CI2 [/ip neighbor get [find interface="ether2"] platform]
:if ($CI2="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether2"]}}
:if ($CI2="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether2"]}}}
:if ([/interface get ether3 running] = true) do={
:global CI3 0
:global CI3 [/ip neighbor get [find interface="ether3"] platform]
:if ($CI3="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether3"]}}
:if ($CI3="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether3"]}}}
:if ([/interface get ether4 running] = true) do={
:global CI4 0
:global CI4 [/ip neighbor get [find interface="ether4"] platform]
:if ($CI4="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether4"]}}
:if ($CI4="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether4"]}}}
:if ([/interface get ether5 running] = true) do={
:global CI5 0
:global CI5 [/ip neighbor get [find interface="ether5"] platform]
:if ($CI5="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether5"]}}
:if ($CI5="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether5"]}}}
:if ([/interface get ether6 running] = true) do={
:global CI6 0
:global CI6 [/ip neighbor get [find interface="ether6"] platform]
:if ($CI6="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether6"]}}
:if ($CI6="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether6"]}}}
:if ([/interface get ether7 running] = true) do={
:global CI7 0
:global CI7 [/ip neighbor get [find interface="ether7"] platform]
:if ($CI7="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether7"]}}
:if ($CI7="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether7"]}}}
:if ([/interface get ether8 running] = true) do={
:global CI8 0
:global CI8 [/ip neighbor get [find interface="ether8"] platform]
:if ($CI8="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether8"]}}
:if ($CI8="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether8"]}}}
:if ([/interface get ether9 running] = true) do={
:global CI9 0
:global CI9 [/ip neighbor get [find interface="ether9"] platform]
:if ($CI9="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether9"]}}
:if ($CI9="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether9"]}}}
:if ([/interface get ether10 running] = true) do={
:global CI10 0
:global CI10 [/ip neighbor get [find interface="ether10"] platform]
:if ($CI10="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether10"]}}
:if ($CI10="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether10"]}}}
:if ([/interface get ether11 running] = true) do={
:global CI11 0
:global CI11 [/ip neighbor get [find interface="ether11"] platform]
:if ($CI11="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether11"]}}
:if ($CI11="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether11"]}}}
:if ([/interface get ether12 running] = true) do={
:global CI12 0
:global CI12 [/ip neighbor get [find interface="ether12"] platform]
:if ($CI12="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether12"]}}
:if ($CI12="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether12"]}}}
:if ([/interface get ether13 running] = true) do={
:global CI13 0
:global CI13 [/ip neighbor get [find interface="ether13"] platform]
:if ($CI13="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether13"]}}
:if ($CI13="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether13"]}}}
:if ([/interface get ether14 running] = true) do={
:global CI14 0
:global CI14 [/ip neighbor get [find interface="ether14"] platform]
:if ($CI14="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether14"]}}
:if ($CI14="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether14"]}}}
:if ([/interface get ether15 running] = true) do={
:global CI15 0
:global CI15 [/ip neighbor get [find interface="ether15"] platform]
:if ($CI15="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether15"]}}
:if ($CI15="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether15"]}}}
:if ([/interface get ether16 running] = true) do={
:global CI16 0
:global CI16 [/ip neighbor get [find interface="ether16"] platform]
:if ($CI16="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether16"]}}
:if ($CI16="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether16"]}}}
:if ([/interface get ether17 running] = true) do={
:global CI17 0
:global CI17 [/ip neighbor get [find interface="ether17"] platform]
:if ($CI17="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether17"]}}
:if ($CI17="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether17"]}}}
:if ([/interface get ether18 running] = true) do={
:global CI18 0
:global CI18 [/ip neighbor get [find interface="ether18"] platform]
:if ($CI18="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether18"]}}
:if ($CI18="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether18"]}}}
:if ([/interface get ether19 running] = true) do={
:global CI19 0
:global CI19 [/ip neighbor get [find interface="ether12"] platform]
:if ($CI19="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether19"]}}
:if ($CI19="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether19"]}}}
:if ([/interface get ether20 running] = true) do={
:global CI20 0
:global CI20 [/ip neighbor get [find interface="ether20"] platform]
:if ($CI20="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether20"]}}
:if ($CI20="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether20"]}}}
:if ([/interface get ether21 running] = true) do={
:global CI21 0
:global CI21 [/ip neighbor get [find interface="ether21"] platform]
:if ($CI21="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether21"]}}
:if ($CI21="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether21"]}}}
:if ([/interface get ether22 running] = true) do={
:global CI22 0
:global CI22 [/ip neighbor get [find interface="ether22"] platform]
:if ($CI22="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether22"]}}
:if ($CI22="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether22"]}}}
:if ([/interface get ether23 running] = true) do={
:global CI23 0
:global CI23 [/ip neighbor get [find interface="ether23"] platform]
:if ($CI23="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether23"]}}
:if ($CI23="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether23"]}}}
:if ([/interface get ether24 running] = true) do={
:global CI24 0
:global CI24 [/ip neighbor get [find interface="ether24"] platform]
:if ($CI24="MikroTik") do={/interface bridge port {set bridge=bridgeVLAN [find interface="ether24"]}}
:if ($CI24="0") do={/interface bridge port {set bridge=bridgePUBLIC[find interface="ether24"]}}}
The only thing is, if i run it via terminal command in things like hap lites , ac lites they start smoking…
So i need something that is much more simple, i know its possible, but i cant figure it out,
i’ve already tried tis:
:global CI 0
do {
:foreach true in=[/interface find name~"ether[2-24]"running] do={
:global CI [/ip neighbor get [find interface~"ether[2-24]"] platform]
:if ($CI="MikroTik") do={interface bridge port {set bridge=bridgeVLAN [find interface~"ether[2-24]"]}}
but you can guess, it didnt work…
who can help me?
