Hey everyone…it’s been a while since I’ve been active up here…but now I’m in a bit of a bind and need some help with setting up my new hex.
Situation: I have an older RB750GL that’s been running great for a while (ROS 6.40.5) using the older Master/slave port setup. I recently had to change an address on one of my VLAN interfaces, and accidentally changed the wrong interface, locking myself out of the router. Even worse, my backups are all on my storage server, which recently suffered a hardware failure, so I can’t get at my backups. Since most of my network was still running, I opted to buy a hex (RB750Gr3 on ROS 6.43.11). I know that the Master/slave switch setup has been replaced with Bridge, but I can’t for the life of me figure out how to get it configured correctly such that I can just swap out the RB750GL and hex and get my network fully operational again.
Here’s what I remember of the 750GL setup: ether1 was my Internet connection (default config on the hex, so no problem there); ether2 (Master) and ether3 are trunk ports, ether4 and ether5 are access ports. All addresses were on VLAN interfaces assigned to ether2.
What I need: a working config script that puts VLANs 100, 200, 300, 501, 801, and 901 on the router; Management IP address (preferably 172.16.0.30/27) on VLAN 100 (needs functional DHCP server on this interface as well); ether 2 and 3 configured as trunk ports carrying all VLANs, ether 4 and 5 configured as access ports for VLAN 100. The other VLAN interfaces need to have IP addresses, but no DHCP server (actual addresses used for this initial config don’t matter as long as routing works; I can change the addresses to suit my network).
Normally, I’d take the time to really learn what I’m doing wrong (I have a feeling it’s something obvious, but I’m beyond frustrated at this point), but I just started my own business and I need to get my lab fully functional ASAP. Please help! And big thanks in advance to anyone and everyone who helps me get out of this nightmare.
You might want to start by this link then: http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
I don’t know about VLANs tho, I only bridge for now (home).
Hey tough luck…
Not the whole config but pointers, some todo’s left for you:
eth2 & 3: trunk: all vlans should be tagged on these ports
ex: /interface bridge port add bridge=bridge1 interface=ether2
eth4 & 5: only untagged traffic with definition of default vlan
ex: /interface bridge port add bridge=bridge1 interface=ether4 pvid=200
make sure to include bridge itself for all vlans which need to be routed
ex: /interface bridge vlan add bridge=bridge1 tagged=ether2,ether3,bridge untagged=ether4 vlan-ids=100
- addresses
these need to be assigned to vlan interfaces linked to the bridge “/bridge vlan”
ex: /interface vlan add interface=bridge1 vlan-id=100 name=v100
/ip address add interface=v100 address=…
Thanks! So far so good…but here’s the next piece…I’ve added a DHCP server to my “Management” VLAN (100) interface, and I can get an address, so that works fine. However, I am unable to connect to the address I put on that interface via Winbox (using IP or MAC) or mactelnet. I can still connect to the default 192.168.88.1 address that is assigned directly to the bridge (I left ether5 on pvid=1 until I get things finalized), but I’d like to ditch that and just use the address I have assigned to my Management VLAN interface. Does this newer version of ROS require an address directly on the bridge? On my older setup, I only had to have addresses on the VLAN interfaces and could access all enabled management services (Winbox, ssh, Webfig), assuming my firewall input chain allowed it (which I had restricted ONLY to the Management VLAN IP address).
Here’s my export so you can see where I am…
add admin-mac=B8:69:F4:AE:58:0E auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface vlan
add interface=bridge name=DMZ vlan-id=300
add interface=bridge name=GuestWireless vlan-id=901
add interface=bridge name=InternalWireless vlan-id=801
add interface=bridge name=MediaLAN vlan-id=501
add interface=bridge name=Mgmt vlan-id=100
add interface=bridge name=ServerLAN vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=Mgmt-pool ranges=172.16.0.20-172.16.0.24
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=Mgmt-pool disabled=no interface=Mgmt name=Mgmt
add bridge=bridge comment=defconf interface=ether4 pvid=100
add bridge=bridge tagged=ether2,ether3,bridge untagged=ether4 vlan-ids=100
add bridge=bridge tagged=ether2,ether3,bridge vlan-ids=200
add bridge=bridge tagged=ether2,ether3,bridge vlan-ids=300
add bridge=bridge tagged=ether2,ether3,bridge vlan-ids=501
add bridge=bridge tagged=ether2,ether3,bridge vlan-ids=801
add bridge=bridge tagged=ether2,ether3,bridge vlan-ids=901
192.168.88.0
add address=172.16.0.30/27 interface=Mgmt network=172.16.0.0
add address=10.1.150.254/24 interface=ServerLAN network=10.1.150.0
add address=172.31.120.30/27 interface=DMZ network=172.31.120.0
add address=172.18.0.30/27 interface=MediaLAN network=172.18.0.0
add address=10.1.168.30/26 interface=InternalWireless network=10.1.168.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/16
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/tool mac-server
/tool mac-server mac-winbox
Regarding mac servers
/tool mac-server
but only bridge is added to LAN, and that means untagged traffic / vlan=1.
Don’t you want /ip dhcp-server network config for mgmt?
Can you ping Mgmt ip over mgmt vlan? Probably yes, but nothing else right? → firewalled, as mgmt isn’t part of LAN
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
Ah! The concept of grouping interfaces as LAN is a little odd to me. After assigning the Management VLAN interface to LAN, I’m able to reach my desired management IP address both from an access port on my management VLAN as well as routing from the default 192.168.88.0 network to the management IP. Looks like I just need to add all my trusted VLAN interfaces to LAN and then rely on the firewall to block access via certain addresses.
This is so much more confusing than the old Master/Slave port arrangement, but it’s not like I really have a choice at this point. Thanks again!
You can define multiple interface lists and have separate firewall rules for each or just for the mgmt interface itself.
I would recommend to to isolate your management and permissions from the rest.
