need some help plz
i have router RB750 this is my sitting
wan :
10.0.0.5/24
local
192.168.0.1
192.168.10.1
i want to put cash proxy (ipcop) in the locla interface
1-i dont know how to makeit work and what the rolls i but in the system.
2- if i want to but secand router in the system to make loade balnece did i need to conect the cash server to the secand router
u can always use parent proxy and point that to your external proxy and port…
u have first to enable your web proxy and specify the parent proxy (cash proxy) and port, then if you want to make it transparent u will have to create a dst-nat rule to redirect your traffic from port 80 to 8080 and that would be all…
itry to do that but its fail can u tell me the way exactly cuz im new in routerbord :slight_smile:
okay first try first creating a proxy in your routerboard like this…i guess ur using winbox
I am assuming that you already made ur LAN work…(internet withing ur LAN with a masquerading network)
First enable the webproxy…u don’t have to do anything besides that
Second create a firewall rule and place it before your masquerading rule
/ip firewall nat add chain=dstnat protocol=tcp dst-port=80 action=redirect to-ports=8080
you can copy that statement and paste it on the terminal in winbox…
That rule has to go in first place on your NAT rules…the masquerade can go on second place (to allow all other types of traffic that is not port 80)
if that works…then we’ll try with the parent proxy settings
thank u mr andrescamino for u replay .
yes i have the lan work right and i have also hotspot work very will …
when i post that roll nothing happen and no hit in the proxy
so the only thing that don’t work is the parent proxy??
