Hi there! I could really use some help. Here’s the situation: I’m running a Hap ax3 on the latest stable firmware, and I've already got containers enabled. I've installed the nfqws2-mikrotik container following the instructions to a tee. All the routing is set up exactly as the guide says. The container starts fine, and there are no errors in the logs.
However, as soon as I route traffic from my PC through the container, no websites will load. The weird thing is that tracert (to YouTube or any other site) works perfectly and shows the traffic passing through the container.
I also tried setting up DoH (Comss.one DNS) on the MikroTik, but it didn't help.
Here is the traceroute showing that the traffic is indeed hitting the container:"
1 <1 мс <1 мс <1 мс router.lan [192.168.1.1]
2 <1 мс <1 мс <1 мс 192.168.254.7 -IP контейнера
3 <1 мс <1 мс <1 мс 192.168.254.1
4 * * * Превышен интервал ожидания для запроса.
5 36 ms 1 ms 57 ms Router.sknt.ru [93.100.0.148]
6 1 ms 1 ms <1 мс K12-CORE [93.100.0.46]
7 * * * Превышен интервал ожидания для запроса.
8 * * * Превышен интервал ожидания для запроса.
9 * * * Превышен интервал ожидания для запроса.
10 1 ms 1 ms 1 ms 72.14.216.110
11 1 ms 1 ms 1 ms 172.253.76.91
12 8 ms 1 ms 1 ms 74.125.244.181
13 * * 5 ms 142.251.51.187
14 5 ms 6 ms 5 ms 72.14.236.73
