Need some help, thanx, RB2011 UiAS RM / RBmAP2n + TL-WN722N / AWUS036NH
:open_mouth: I have tried different combinations between this hardware. 2 mt routers (both 6.30.2) and 2 wireless usb devices.
MT is RB2011 Ui AS RM / RBmAP2n
Wlan USB is TL-WN722N / AWUS036NH connected via OTG
Even try to install all packages, and try different: wireless-cm2 / fp packages.
Nothing is happens and wlan interfaces were empty / different OTG cables.
Logs are empty.
I try to google it but fail.
All I want this to add wlan
Thanks for help ( ^^)(^^ )?
2011RM
mAP
just photo
Hi, after few month I still trying to join the hardware. And still nothing.
Alfa won’t work. Mikrotik can use only SOME Atheros adapters.
Please check compatibility list :
http://wiki.mikrotik.com/wiki/Supported_Hardware#USB_wireless_cards
If you need Wireless, buy a wireless routerboard… it will perform better than USB card, and will cost almost the same (hAP Lite, for example)
Regards
Don’t bother anymore, it wont work.
I have ALFA from compatibility list 802 b/g/n AR9271 ALFA AWUS036NHA USB 5.14 x86 works :smiley: with Altheros
But it doesn’t work.
The same TP-Link works fine with RB951 but not with RB2011 RM
I use both of this cards for Kali linux so all works, but not with the RB2011 RM
Any suggestions?
