Need some help wrapping my head around (and configuring) a VLAN
I have a pfsense router/gateway and a dd-wrt access point. Following this guide http://phil.lavin.me.uk/2012/10/creating-a-guest-wifi-with-802-1q-vlan-tagging-in-pfsense-and-dd-wrt/ I created a guest network on the AP and assigned it to vlan4. I then created a vlan and an interface in pfsense and set up a DHCP server on it. However, I believe my switch (model CRS226-24G-2S+) is preventing my access point and router from communicating over that vlan. I created a bridge (bridge-vlan4) and two vlan interfaces (eth1-vlan4, eth6-vlan4) on my switch, but that doesn’t seem to have helped so far. I posted what I hope are the relevant configs below. I just updated to RouterOS 6.42.9 (from 6.40.8 ) so if any of this is the “old way” of doing things I’d love to know that as well. Any help is greatly appreciated, and please let me know if you would like to see any more configurations.
/interface bridge print
 0 R name="bridge-vlan4" mtu=auto actual-mtu=1500 l2mtu=1584 arp=enabled arp-timeout=auto mac-address=4C:5E:0C:9B:CD:68 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m
     priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=yes pvid=4
 1 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1588 arp=enabled arp-timeout=auto mac-address=4C:5E:0C:9B:CD:68 protocol-mode=rstp fast-forward=no igmp-snooping=no auto-mac=no admin-mac=4C:5E:0C:9B:CD:68
     ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no
/interface vlan print
 #   NAME        MTU ARP             VLAN-ID INTERFACE
 0 R eth1-vlan4        1500 enabled               4 ether1
 1 R eth6-vlan4        1500 enabled               4 ether6
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE        BRIDGE        HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ether1        bridge1                                                               yes    1     0x80         10                 10       none
 1     eth1-vlan4                                                               bridge-vlan4        4     0x80         10                 10       none
 2     eth6-vlan4                                                               bridge-vlan4        4     0x80         10                 10       none
 3   H ether2        bridge1                                                               yes    1     0x80         10                 10       none
 4   H ether3        bridge1                                                               yes    1     0x80         10                 10       none
 5   H ether4        bridge1                                                               yes    1     0x80         10                 10       none
 6 I H ether5        bridge1                                                               yes    1     0x80         10                 10       none
 7   H ether6        bridge1                                                               yes    1     0x80         10                 10       none
 8 I H ether7        bridge1                                                               yes    1     0x80         10                 10       none
 9   H ether8        bridge1                                                               yes    1     0x80         10                 10       none
10   H ether9        bridge1                                                               yes    1     0x80         10                 10       none
11 I H ether10        bridge1                                                               yes    1     0x80         10                 10       none
12 I H ether11        bridge1                                                               yes    1     0x80         10                 10       none
13 I H ether12        bridge1                                                               yes    1     0x80         10                 10       none
14   H ether13        bridge1                                                               yes    1     0x80         10                 10       none
15 I H ether14        bridge1                                                               yes    1     0x80         10                 10       none
16   H ether15        bridge1                                                               yes    1     0x80         10                 10       none
17 I H ether16        bridge1                                                               yes    1     0x80         10                 10       none
18   H ether17        bridge1                                                               yes    1     0x80         10                 10       none
19 I H ether18        bridge1                                                               yes    1     0x80         10                 10       none
20 I H ether19        bridge1                                                               yes    1     0x80         10                 10       none
21   H ether20        bridge1                                                               yes    1     0x80         10                 10       none
22 I H ether21        bridge1                                                               yes    1     0x80         10                 10       none
23   H ether22        bridge1                                                               yes    1     0x80         10                 10       none
24 I H ether23        bridge1                                                               yes    1     0x80         10                 10       none
25 I H ether24        bridge1                                                               yes    1     0x80         10                 10       none
26   H sfp1        bridge1                                                               yes    1     0x80         10                 10       none
27 I H sfp2        bridge1                                                               yes    1     0x80         10                 10       none
You cannot make ether1 a member port of a bridge (here called bridge1) and at the same time a bearer port of an /interface vlan.
So just removing the two /interface vlan and keeping vlan-filtering=no on bridge1 would allow frames tagged with VID 4 to flow between ether1 and ether6 - in fact, frames with any VID flow freely between any pair of member ports of the same bridge when vlan-filtering is set to no.
If you want to precisely control which VLANs are permitted on which ports and whether they are tagged or tagless on these ports, you have to set vlan-filtering to yes on the bridge, but before doing that, you have to use /interface bridge vlan to configure port membership in VLANs and /interface bridge port to configure pvid for each port.
So for your case, you would have to remove the two /interface vlan and the /interface bridge name=bridge-vlan4, and set
add vlan-ids=1 bridge=bridge1 untagged=bridge1,ether1,ether2,…,sfp2
add vlan-ids=4 bridge=bridge1 tagged=ether1,ether6
add bridge=bridge1 interface=ether1 pvid=1
add bridge=bridge1 interface=sfp2 pvid=1
And, finally,
/interface bridge set bridge1 pvid=1 vlan-filtering=yes.
This way, you’d make ingress tagless frames on any port remain tagless on the bridge because the pvid of the ports and the pvid of the bridge is the same (this is something that doesn’t happen on usual switches where everything must be tagged internally), and permit frames tagged with VID 4 on ether1 and ether6.
A bridge itself must be present in the list of tagged or untagged ports of itself under /interface bridge vlan if you want to attach an IP configuration to it. That’s why I’ve put it to the untagged list on the row for vlan-ids=1
