I would like to know if anyone currently using any script to pull information from user-manager that they can share.
My thinking is, if a search can be done for all users whose uptime is greater than lets say ‘4w’, any matching result could then be printed to a file with the users’ info then email to a specific address. The information gathered would then be email to the user telling them the billing cycle is approaching and further action can be taken on their part.
As I am learning the scripting interface, I’ll be testing some operators along with some ICE command to see what comes up. I would like anyones input, no matter how small or even just an idea of where to start.
Here's a little something I whipped up to see if I can write something like this,
coz I need something similar. Haven't gotten to the E-mailing thing yet,
but I'll take a stab at it.
Here's what I have so far:
This is my source code just pasted. With some comments.
#define a couple of variables
:local uptime
:local count
:local usrname
Loop through all the users in User Manager
/tool user-manager user
:foreach i in=[ /tool user-manager user find subscriber=admin ] do={
#pull some data from it, and print it on screen
:set usrname [get $i name]
:set uptime [get $i uptime-used]
:put $uptime
:put $usrname
tell us on screen if the user is under or over 4 weeks:
:put $count
So run that, and check the output. Let me know if there's a bug.
I've only tested it for Over or Under 30 Second durations - works fine.
Have two test accounts - Test1 and Test2, logged in for 34s and 12s respectively.
Generates the correct output.
:local uptime
:local count
:local usrname
:local clientname
:local clientsurname
#Pull some data from it, and print it on screen - #You can take the PUT commands out to not display it on screen
:set clientname [get $i first-name]
:set clientsurname [get $i last-name]
:put $uptime
:put $usrname
:put $clientname
:put $clientsurname
30s is the amount of uptime that I am testing for:
tell us on screen if the user is under or over 30 Seconds: - again, you can take this out
:put $count
#Now, send an E-mail to the user that greets the user by name with his Over-Uptime status:
:if ([$count] = "Uptime over 30 Seconds") do={/tool e-mail send to=client@yourISP.com from=you@yourISP.com server=1.2.3.4 body="Dear $clientname $clientsurname
You have reached your allowed uptime.
Your current uptime is $uptime
I used your accounting script from the WiKi and rewrote several parts of it.
I managed to use the transfer-limit from UM instead of the one you specified using the comment field.
Currently the script sends out notifications when a user reach 50%, 75%, 90% and also when a user is capped. It also sends me an email telling me what was sent to the user, and the moment a user is capped, I also get an e-mail.
I went one step further and wrote another script to send me all the 50%, 75%, 90% and capped users in seperate E-Mails DAILY. It is sometimes nice to know who’s approching their cap and who already got capped.
Usermanager lacks the functionality to sort by the amount of GB or MB is left of users’ cap, so this is my little workaround for that.
If anyone is interested in the script, please let me know so I can past it!
