Need Suggestion CCR
Dear Exports,
Above is my existing configs, but I need 100Mbps more, from existing provider, will provide another Line.
Please advise
Typo Mistake … Experts.
Why can’t they LACP trunk the 2 ports together to give you 200Mb?
The mentioned 154 Mbps by your carrier make the access technology smell like ATM.
LACP over ATM might create some issues :slight_smile:
Therefore as you have a CCR you might ask your provider to host a small mikrotik for you at one of their PoPs near you.
using eg. EoIP-tunnels over each 100M link you get you could bond those together and aggregate those links.
in case you can get your provider to deliver 2 x 100M as LACP link to your C3750 you should take that offer, it’s as simple as setting up a Port-Channel interface and you’re done.
EoIP bonding is described in a quite similar fashion (wireless instead of two carrierlinks via ATM) here: http://wiki.mikrotik.com/wiki/Manual:Bonding_Examples
Regards
hk
