Someone please suggest in concern of RouterOS 6.xx ,1Gbps Bandwidth x86 hardware…
- Motherboard
- Processor
- RAM
etc.
Thanks & Regards
Shuvodip Roy
Thanks & Regards
Shuvodip Roy
That’s a fairly broad category, can you tell us more about your requirements?
How many ethernet ports do you need?
Do you need something rack mountable?
Do you have size constraints?
Does it need to be silent?
Does it need to be cheap?
Are you going to use virtualisation, and if so, do you need to run anything else on the same machine other than RouterOS?
Depends on the ethernet ports you need and whether you need wifi as well.
There are many good choices in China.
I am using one with 6 giga ports and 1037u CPU in an A4 size. Inexpensive and quiet
Costs less than US$150 and I brought a 128GB SSD and a level 4 licence
