need the changelog of firmware 2.20 RB 600
Hello, need the changelog of firmware 2.20 RB 600.
What’s new in 2.25:
*) fixed etherboot on RB493;
*) fixed occasional lockup of kernel image loading on RB400 series;
*) added disable UART feature;
What’s new in 2.24:
*) added support for RB816;
What’s new in 2.23:
*) added support for RB750G;
*) added support for RB800;
What’s new in 2.22:
*) fixed support for RB750;
What’s new in 2.21:
*) added support for RB750;
What’s new in 2.20:
*) added support for RB450G;
What’s new in 2.19:
*) fixed support for MLC NAND chip;
*) fixed memory issue on RB600;
What’s new in 2.18:
*) fixed via-rhine disappearing on RB532 and RB564;
*) added support for RB493AH;
What’s new in 2.17:
*) added support for MLC NAND chip;
What’s new in 2.16:
*) fixed bug - boot from NAND on RB532A could fail (bug introduced in 2.13);
*) fixed bug - etherboot on RB433/RB450 at 10Mbit did not work;
Why is not there?
http://www.routerboard.com/files/rb-2.22/CHANGELOG
What are the changes in the firmware 2.24 for the RB800?
Why can not you write changelog as it was before? To file http://www.routerboard.com/files/rb-2.24/CHANGELOG?
nothing new. I updated the post above. only support for new products added. that’s all
Where to download 2.25? Thanks
All firmware updates are integrated into the software. Upgrade RouterOS to v4.5 and then type “/system routerboard upgrade”. It will then update to the latest version that’s available for your board model. NOTE: different boards have different versions. For some v2.23 is the latest version.
I just wanted to firmware 2.25 for the platform mipsbe. But I do not yet upgraded to 4.x. On routerboard.com is so far only firmware 2.23.
if it’s not on the webpage (routerboard.com) then there is no newer version for your model.
Now that is very cool - just remember that you have to remove all previous copies from files before or it will only recognize those.
So much easier and I learned it here!!
Thanks, Normis!!
Can we get a regular location for RouterBoot changelogs that gets updated?
Thanks,
Tom
http://wiki.mikrotik.com/wiki/RouterBOOT_changelog
Where is changelog for 2.29 ?
Updated
and 2.30? Website is again outdated
check again
Some bug in 2.30? It was a download, but not now
http://www.routerboard.com/pricelist.php
which product?
I meant 2.30. Error in previous post
All mipsbe version offers only 2.29
it means there is no newer version available, apparently there was a mistake previously. only PPC has v2.30
