I’m setting up an IPSec VPN between a Mikrotik Router on my side and a Fortigate FG30 Firewall on the other organization’s side. Essentially my company is opening a store inside their organization, and we are trying to route all of the store’s traffic through the IPSec VPN to my network, so that all services including internet access pass through the VPN.
We have the IPSec VPN working LAN to LAN, where all devices on each side of the LANs can communicate accross the tunnel. My LAN IP range is 10.0.0.0/12. The store’s LAN IP range is 10.90.0.0/24.
What doesn’t work and what we desire to work is to pass all Internet traffic from the store over the tunnel and then out my public IP. The other organization doesn’t want any of the Store’s traffic to pass through it’s local network. Here is my IPSec configuration:
/ip ipsec peer profile
add dh-group=modp2048,modp1536 enc-algorithm=aes-256,aes-128,3des hash-algorithm=sha256 name=RRC nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=3des
add auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm,3des name=RRC pfs-group=modp2048
/ip ipsec peer
add address=StorePublicIP comment=“Store” local-address=MyPublicIP profile=RRC secret=****
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.90.0.0/24 level=unique proposal=RRC sa-dst-address=StorePublicIP sa-src-address=MyPublicIP src-address=0.0.0.0/0 tunnel=yes
My NAT configuration is as follows:
add action=accept chain=srcnat comment=“Store NAT Rule” dst-address=10.90.0.0/24 src-address=10.0.0.0/12
add action=masquerade chain=srcnat comment=“Masquerade for Store” src-address=10.90.0.0/24
add action=masquerade chain=srcnat comment=“Masquerade to public IP” log-prefix="NAT: " out-interface=“Public Internet Bridge”
What do I need to do to accept Internet bound traffic from the IPSec tunnel and route it out my Public internet interface?
Thank you.
I’m having no luck configuring the Mikrotik router to allow Internet access, even through NAT. I’m going to try to setup a proxy server on my side of the tunnel and see if the proxy can avoid the need to route the traffic directly out the public interface, since the proxy is on the local network which is accessible from the far side of the IPSec tunnel.
If traffic from store to internet (i.e. to addresses other than 10.0.0.0/12) is able to reach your router over IPSec tunnel, then routing it to internet should work. Router sees it as traffic from WAN to WAN, but if you don’t block it in firewall filter, it’s fine.
Other approach (if Fortigate can do it, unfortunately I don’t know that) is to drop IPSec in tunnel mode, create GRE tunnel between routers and only secure GRE traffic with IPSec. It will give you regular interfaces and they are generally easier to work with, because it’s just normal routing.
Thank you very much, Sob, your help let me find the solution.
Using the troubleshooting tips you passed on below, I found an error in my NAT rule, and we discovered a missing route on the Fortigate store side of the tunnel. After correcting both these items, all traffic including Internet traffic is passing through the IPSec tunnel as expected. During our testing we did try to get a GRE tunnel up, but eventually abandoned that effort.
The corrected NAT rule is:
add action=accept chain=srcnat comment=“Store NAT Rule” dst-address=10.90.0.0/24 src-address=0.0.0.0/0
That rule prevented following masquerade rule from touching traffic from 10.0.0.0/12 to 10.90.0.0/24, which would break the tunnel for connections initiated from 10.0.0.0/12 to 10.90.0.0/24. Btw, same thing could be achieved by adding ipsec-policy=out,none to main masquerade rule. But it wouldn’t affect the other direction. And you don’t need anything else for traffic from 10.90.0.0/24 to internet. Only problem could be for forwarded ports from public address to 10.90.0.0/24, if there are any.
Hi!. I have an issue similar to the one described here. I have two sites (remote: 10.0.0.0/16 and local to Mikrotik:172.16.0.0/16) connected through an IPSec VPN tunnel and I want to allow the remote site (AWS VPC 10.0.0.0/16) to go to internet through the Mikrotik router. The site2site vpn traffic is OK, I can see the traffic from the remote site getting into the Mikrotik prerouting mangle chain with the public IP as the destination and the source private IP of the instance I’m testing from, but not in the postrouting.
Hi! I found what the problem was. In the IPsec policy to get to the 10.0.0.0/16 subnet, my src-net was the local network. I changed it to 0.0.0.0/0 and Mikrotik started to route the internet traffic. This is a working config.
Without it, the default route will not be advertised to the peer on the other side. Specifically for AWS, even if your VPC/subnet route table has a rule for 0.0.0.0/0 to vgw, it will still be dropped by the site-to-site VPN connection because it doesn’t have that BGP-provided route (again, assuming you are using BGP/dynamic routing and not static).
