I’m using RB951 series with userman. Can anyone tell how to set daily internet limit let’s say 100mb per day and want to set it for 30 days (a month).
Thank you.
Thank you.
You can set a limit for each profile you create… i do not remember right now if it can be daily or not… you can check it out…
Hi Zacharias,
Thanks for the reply,
Right now I have set validity. I don’t know if that will work, will check later.
Validity will just expire the users profile…!
Untils the user gets assigned a new profile, no access to the internet will be available…
