Hi all
Please see this:
Can someone give me some steps on how to do this setup? i am very new to this kind of stuff so i would need some very easy steps. Thanks a lot
Hi all
Please see this:
You could use PPTP to do this. Check out the following link.
http://wiki.mikrotik.com/wiki/Manual:Interface/PPTP#Connecting_Remote_Client
AFAIK you just have to run like a PPTP VPN server on the MikroTik and then connect to it from your laptop. You’ll also have to create a new Secret (username, password, local & remote addresses) for you to be able to log in and get an IP address from the VPN server.
Unfortunately you’ll have to add static routes on your laptop for those internal hosts, unless you’re fine with all the Internet traffic also passing through the VPN.
Hi all
The same problem is reported here:
http://forum.mikrotik.com/t/how-to-configure-450g-with-this-setup/37646/14
Only problem I got is that I cant ping to internal hosts when I am connected to the PPTP server.
Any help?
Finally I managed to find the solution. Just enabled proxy-arp on the BRIDGE interface!
