need to show ccq & noise floor for rb 911
Hello
which is the best way to do that
please how i can do that
Use the proper OIDs…
You can get the OIDs for any section in the CLI:
/interface wireless> print oid
 0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.2.9
   rx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.3.9
   ssid=.1.3.6.1.4.1.14988.1.1.1.3.1.4.9
   bssid=.1.3.6.1.4.1.14988.1.1.1.3.1.5.9
   client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.6.9
   frequency=.1.3.6.1.4.1.14988.1.1.1.3.1.7.9
   band=.1.3.6.1.4.1.14988.1.1.1.3.1.8.9
   noise-floor=.1.3.6.1.4.1.14988.1.1.1.3.1.9.9
   overall-ccq=.1.3.6.1.4.1.14988.1.1.1.3.1.10.9
check you have the updated MIB loaded on the dude and do a snmp walk to check proper oid
create a probes like this
then add services to devices using created probes
