Need to upgrade v5.0rc10 but can't reboot
Hi!
Been running v5.0rc10 for several months on x86. All is ok, but i can never reboot the device as it hangs permanently. Then I have to take a trip, and manually turn it off and on.
Was thinking of upgrading to 5.1 which I read on the change-log should rectify my problems.
BUT, i was under the impression that in order to upgrade, you need to copy the files over then choose reboot from the tools menu. As i am unable to reboot, without manually turning the device on and off, I was wondering how to upgrade!
Any suggestions welcome!
You can also upgrade with netinstall.
