HI
i have installed router OS on a pc. It has got a on board lan card and a external Dlink.
When i boot it detects the dlink but not tyhe onboard.
Also when i give dlink internal ip e.e 192.168.1.99/24 and gateways 192.168.1.1 which is my adsl router.
i cannot ping it nor can i connect it using winbox.
what should i use cross cable or straight cable to connect to ADSL switch.?
can i confrigure the mikrotik only with one lan card as i want to use it for internet and bandwidth control
Thanks in advance for the help
cheers!
