hasmac
January 29, 2013, 6:14pm
1
Hey guys i am new to mikrotik i need your help !!
i am using mikrotik 5.2 level 6 version.
my local area ip address series starts from : 172.16.0.1
subnet mask is : 255.255.0.0
problem is that my friend is also a internet service provider and he is providing LAN Entertainment Server to his customer..
i want to merge his local area network to my network means i want to run his LAN entertainment server to my network …
is there any way to do that??
his local area server ip is : 192.168.173.104
You can create a eoip tunnel with your friend Mikrotik Router and use same IP block which is used your friend Local Environment. But If your friend use another router then you can use those server through VPN connection
hasmac
January 29, 2013, 7:44pm
3
hey first of all thanks for your reply !!
will you plz tell me how to make vpn?
and one thing more my friends told me that it is possible through route too…
i dont know how to setup route and all will you please help me?
hasmac
January 29, 2013, 7:45pm
4
and i am using HotSpot for my network… i think VPN will not be suitable?
