Needed Support for OSPF
I have setup DHCP server with OSPF internal route but still users are not getting connected to other interface network
[admin@AXiS] interface> print
Flags: X - disabled, D - dynamic, R - running
 #    NAME        TYPE             RX-RATE    TX-RATE    MTU
 0  R LAN        ether            0          0          1500
 1  R WAN        ether            0          0          1500
[admin@AXiS] ip address> print detail
 0   address=172.16.0.1/16 network=172.16.0.0 broadcast=172.16.255.255 interface=LAN actual-interface=LAN
 1   address=192.168.202.111/24 network=192.168.202.0 broadcast=192.168.202.255 interface=WAN actual-interface=WAN
[admin@AXiS] ip dns> print
            primary-dns: 192.168.202.1
          secondary-dns: 208.67.222.222
  allow-remote-requests: yes
             cache-size: 2048KiB
          cache-max-ttl: 1w
             cache-used: 18KiB
[admin@AXiS] ip dhcp-server> print detail
 0   name="webbox" interface=LAN lease-time=5d address-pool=webbox bootp-support=static add-arp=yes authoritative=yes
     always-broadcast=yes use-radius=yes
[admin@AXiS] ip pool> print detail
 0 name="webbox" ranges=172.16.0.2-172.16.255.254
[admin@AXiS] ip dhcp-server network> print detail
 0 address=172.16.0.0/16 gateway=172.16.0.1
[admin@AXiS] radius> print detail
Flags: X - disabled
 0   service=dhcp called-id="" domain="" address=127.0.0.1 secret="XXXX" authentication-port=1812 accounting-port=1813
     timeout=300ms accounting-backup=no realm=""
[admin@AXiS] routing ospf area> print detail
Flags: X - disabled
 0   area-id=0.0.0.0 name="backbone" type=default translator-role=translate-candidate authentication=none
     prefix-list-import="" prefix-list-export=""
[admin@AXiS] routing ospf> print
               router-id: 0.0.0.0
      distribute-default: if-installed-as-type-2
  redistribute-connected: as-type-2
     redistribute-static: as-type-2
        redistribute-rip: no
        redistribute-bgp: no
          metric-default: 1
        metric-connected: 20
           metric-static: 20
              metric-rip: 20
              metric-bgp: 20
[admin@AXiS] routing ospf interface> print detail
 0 interface=all cost=10 priority=1 authentication-key="" network-type=broadcast retransmit-interval=5s transmit-delay=1s
   hello-interval=10s dead-interval=40s
[admin@AXiS] routing ospf network> print detail
 0   network=0.0.0.0/0 area=backbone
please let me know if i missed anything
I can ping 192.168.202.111 [wan ipaddress] from client end
I cannot ping 192.168.202.1 [2008 Server ip address] from dhcp client.
Please Someone Help
could be the routes of the server?
Regards,
