Hello Forum Users,
I’m completely new to MikroTik, and maybe I overestimated my abbilities, but I was not able to configure my wsAP ac lite as a WLAN to LAN bridge.
Because the QuickSet did not work for me (device was not accessible anymore and needed to be reset ) I tried it manual.
I followed several tutorials (written and video) but the connection with the WLAN is not fully established. I even tried to use a spare Accesspoint with a clean configuration to connect to.
Is there some secret step, that I’m missing during the setup?
My steps were:
- make sure there is a bridge that has the WLAN and the Eteernet Ports as Ports.
- Create a new securit profile for the wireless connection
- Setup the wireless conenction (scan for network, connect to, select correct sec. profile)
Then the wsAP tries to connect to the WLAN but has no success…
Thanks a lot for every hint that helps me…
Best Regards
Florian
