I masquerade my clients out behind one IP and for some reason Netflix has banned that IP now.
error message
Whoops, something went wrong.Streaming error.You seem to be using an unblocker or proxy. Please turn off any of these services and try again.”
Clients are showing they have two IP addresses instead of one on whatsmyip.net, one real IP and the other IP’s are fake here is three IPs that showed up 66.249.81.232, 66.249.81.228, 66.249.81.234.
They are not using VPN;s or proxies. I changed the IP of the main router for now and added firewall rules to block vpn’s for clients.
I amended the Nat rules on the main router to /ip firewall nat add action=src-nat chain=srcnat out-interface= to-addresses=<Public_IP>
on the clients cpe’s I have chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix=“” unless they have a static IP address then I use the above rule also
your NAT rule looks fine. if you do trace route, do you get the correct IP?
if it is correct and it still get band, you can contact netflix. I’ve done so recently and they have un-band our public IP.
We are not running any proxy nor VPN and only port open was 8291
