I ran a ping from our mikrotik server to 66.175.96.7, and we’ve -200% packet loss, only 27 packets sent and 81 received…Any idea what could be causing this?
Or maybe not? Here is a Windows box ping to the same ip
C:\Documents and Settings\user>ping 66.175.96.7
Pinging 66.175.96.7 with 32 bytes of data:
Reply from 66.175.96.7: bytes=32 time=78ms TTL=112
Reply from 66.175.96.7: bytes=32 time=89ms TTL=112
Reply from 66.175.96.7: bytes=32 time=75ms TTL=112
Ping statistics for 66.175.96.7:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 75ms, Maximum = 89ms, Average = 82ms
Linux doesn’t like that target ip either. It reports receiving dups.
[root@wifi ~]# ping 66.175.96.7
PING 66.175.96.7 (66.175.96.7) 56(84) bytes of data.
64 bytes from 66.175.96.7: icmp_req=1 ttl=113 time=96.2 ms
64 bytes from 66.175.96.7: icmp_req=1 ttl=113 time=96.3 ms (DUP!)
64 bytes from 66.175.96.7: icmp_req=2 ttl=113 time=76.0 ms
64 bytes from 66.175.96.7: icmp_req=2 ttl=113 time=76.3 ms (DUP!)
64 bytes from 66.175.96.7: icmp_req=3 ttl=113 time=76.1 ms
64 bytes from 66.175.96.7: icmp_req=3 ttl=113 time=76.2 ms (DUP!)
64 bytes from 66.175.96.7: icmp_req=3 ttl=113 time=76.5 ms (DUP!)
64 bytes from 66.175.96.7: icmp_req=4 ttl=113 time=75.6 ms
64 bytes from 66.175.96.7: icmp_req=4 ttl=113 time=75.7 ms (DUP!)
64 bytes from 66.175.96.7: icmp_req=5 ttl=113 time=89.8 ms
64 bytes from 66.175.96.7: icmp_req=5 ttl=113 time=90.5 ms (DUP!)
^C
— 66.175.96.7 ping statistics —
5 packets transmitted, 5 received, +10 duplicates, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 75.670/82.984/96.393/8.668 ms
You are simply receiving duplicate ICMP responces.
This can happen if the IP really is terminated on 3 devices, and all 3 respond to ping requests on that IP.
Since we dont know how the owner of the IP address distributes it internally, and has his equipment configured, this is completly normal.
Hi, I have the same problem. I have perfectly established a connection via sstp between two mikrotik of which one is virtualized. however when trying a ping to google dns, I get negative packet losses.
What could be causing this?
