Hi there;
i have automation project and i am new at scripting. i wanna connect other device with terminal
in terminal
i used
tool romon mac-telnet mac-adress
user
password
it works but when i entered tis code to script area it doesnt work.
How can i do this?
thanx for your help
stunts like that will not work with user/password-authentication (there is no unattended remote-shell usage which needs interaction for authentication - security-reasons)
you need to setup key-authentication between the devices
then you can use … :
[admin@tikki] > system ssh-exec
<address> --
<command> --
as-value --
output-to-file -- write output to file instead of 'output' variable
port --
routing-table --
src-address --
user --
https://wiki.mikrotik.com/wiki/Use_SSH_to_execute_commands_(DSA_key_login)
@cumhureren, what error message do you get?
the script just fails …
it’s a nice “try just at home example”
make yourself acquainted with ssh-key authenticaton !
BUT of course you can try ! … the youngest day … ? … is public !
