Can anyone help me, I have a main map which displays a bunch of sub maps, within these sub maps there a more links to other sub maps, is it possible to have Sub Map1 change status (e.g. red) when a device on Sub Map 2 goes down?
I do not believe that this is possible as each submap is its own isolated entity, as you have probably found trying to test the behaviour yuo require. As Submaps are not available in the parent menu I can not see a way of changing the status of the top level submap.
If submaps could be visible in the parent menu I think your required behaviour could be possible.
Maybe it could be an added feature in the next release?
