NetBEUI over VPN?
Hi!
Gyus, I need help to make VPN with two RB750GL to connect remote terminals to server.
But these terminals running on DR-DOS and using NetBEUI protocol for connection.
Server is Win2003 with NetBEUI protocol installed.
And there is no problem while all of them was in one place. Works perfect over LAN.
But now terminals has moved away.
There is Internet connection on both places.
Is it possible to make VPN with a couple RB750GL and use NetBEUI over it?
Schematics attached :slight_smile:
Please help!
The networks are in the same segment? If so then:
  1. create some sort of VPN between the two routers
  2. create an EOIP tunnel between the networks
Now you have a working netbeui on LAN over VPN.
Yes, the networks is in the same segment.
But… it’s first time I have these devices in my hands.
Can you help me to configure them?
Or maybe some links for tutorials about how to make VPN and EOIP?
