Need help again
rb2011
Vlan1 is wifi network 192.168.10.0/24
vLan 2 is guest 192.168.20.0/24
default LAn is cable attached devices 192.168.88.0/24
I need to have the wifi devices see the Synology on the defaultlan on its device name. nbt netbios wins
i can connect to the synology with ipadres.
Please advise.
Netbios won’t work across routed networks. You need to use either DNS or WINS or something that will work across routing. Netbios needs the computers to be in the same broadcast domain, which is the exact opposite thing the vlans do…
Also as I have noted in the other 3 threads you have running. It is much hard for me/others to keep track of your issues/config if you start multiple threads for the same issues.
Most discovery protocols won’t cross routers. You need to use dns, wins, or something like that. Not sure how to make iTunes work across vlans. I’d have to look of us possible
the vlan1 is even the default vlan and should be used only as a
management vlan for the administrator, likes you in this case! (it is not a must be but more can be thing)
Normally you put devices in different vlans that they are separated each from another, but if you make
the NAS becoming also a member from the WIFI VLAN then the wifi devices can also see the NAS.
That was my point before. Basically you are trying to use protocols that only work within a broadcast domain, but you are using a vlan which has the purpose of separating broadcast domains. There are some proxies to for bonjour etc that allow it to work across broadcast domains, but I have no knowledge of them, thus can’t help you with them.
When i make the NAS member of the VLAN the devices on the LAN cannot connect
As I am right informed can a device such a NAS be a member of more then one VLAN, so it can be reached
from other VLAN members also, ok perhaps MikroTik RouterOS is not dealing with this, then I am sorry!!
